Clear ACL Statistics
Clear default ACL statistics if you no longer require previous statistics.
The ACL statistics do not support security action on some hardware platforms.
Use the information in the following table to use the clear filter acl statistics command.
Variable |
Value |
<1-2048> |
Specifies the ACL ID. |
<1-2000> |
Specifies the ACE ID. |
